[GRASSLIST:7645] Re: GRASS data to ArcView
Ian MacMillan ian_macmillan at umail.ucsb.edu
Wed Jul 20 14:32:43 EDT 2005
Martin, have you tried r.out.bin?  Also, when using r.out.ascii, did
you specify the number of significant digits with dp=?  I might be
wrong, but I don't think tiff supports decimal values.  I am not sure
about the r.out.arc, i haven't really used it before.
-Ian
On Jul 20, 2005, at 8:10 AM, Martin Wegmann wrote:
> Hello,
> I just encountered the problem that my colleagues can't import data
> exported
> from GRASS appropriately into ArcView.
> I tried to convince them to use GRASS but without success so far ,-)
> the raster to export specs are:
> Type of Map:  raster              Number of Categories: 255
> Data Type:    DCELL
> Rows:         2230
> Columns:      3434
> Total Cells:  7657820
> Range of data:    min =  0.000000 max = 35.653061
> r.out.tiff input=test output=test -t //results in 3 bands in ArcView
> not in
> one; from ERDAS I know that I can specify if 1 or 3 (RGB) bands shall
> be
> exported
> r.out.arc input=test output=- > test.grd //results in no image at all
> r.out.ascii does not import as well.
> I recognised missing endings of the exported files. Do I have to add
> certain
> file specifications?
> Any experience with GRASS -> ArcView communication?
> regards, Martin
> Martin Wegmann
> DLR - German Aerospace Center
> German Remote Sensing Data Center
> Dept.of Geography
> Remote Sensing and Biodiversity Unit
> University of Wuerzburg
> Am Hubland
> 97074 Würzburg
> phone: +49-(0)931 - 888 4797
> fax:   +49-(0)931 - 888 4961
> http://www.biota-africa.org
> http://www.biogis.de
