[GRASSLIST:7682] Re: R Stats and GRASS primer (wanted)
Feng Tan
feng at lynxseismicdata.com
Fri Jul 22 11:23:44 EDT 2005
hi, Markus,
When I installing the R/GRASS6.0 interface using your instruction , the
following error showed:
> install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
--- Please select a CRAN mirror for use in this session ---
Error in inherits(x, "factor") : Object "res" not found
what happened?
Thanks,
Feng
On Thursday 21 July 2005 03:15, Markus Neteler wrote:
> [GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
> From:
> Markus Neteler
