[GRASSLIST:7691] Re: R Stats and GRASS primer (wanted)
Markus Neteler neteler at itc.it
Sat Jul 23 04:04:35 EDT 2005
Hi Feng,
I always launched update.packages() before installing the
sp things. Then a Tcl window pops up where I select a mirror
site.
Or: probably you tcl/tk libraries are not installed [properly]?
Markus
On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
> hi, Markus,
> When I installing the R/GRASS6.0 interface using your instruction , the
> following error showed:
> > install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
> --- Please select a CRAN mirror for use in this session ---
> Error in inherits(x, "factor") : Object "res" not found
> what happened?
> Thanks,
> Feng
> On Thursday 21 July 2005 03:15, Markus Neteler wrote:
> > [GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
> > From:
> > Markus Neteler
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
