[GRASSLIST:7703] Re: R Stats and GRASS primer (wanted)
Paolo Cavallini
cavallini at faunalia.it
Mon Jul 25 02:35:28 EDT 2005
This does not happen is a graphic window is not active (e.g. for installations
over ssh, or if root does not have a graphical window).
The solution is to specify the mirror to use.
All the best.
pc
At 10:04, sabato 23 luglio 2005, Markus Neteler has probably written:
> Hi Feng,
> I always launched update.packages() before installing the
> sp things. Then a Tcl window pops up where I select a mirror
> site.
> Or: probably you tcl/tk libraries are not installed [properly]?
> Markus
> On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
> > hi, Markus,
> > When I installing the R/GRASS6.0 interface using your instruction , the
> > following error showed:
> > > install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
> > --- Please select a CRAN mirror for use in this session ---
> > Error in inherits(x, "factor") : Object "res" not found
> > what happened?
> > Thanks,
> > Feng
> > On Thursday 21 July 2005 03:15, Markus Neteler wrote:
> > > [GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
> > > From:
> > > Markus Neteler
Paolo Cavallini
cavallini at faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
