[GRASSLIST:7706] Re: R Stats and GRASS primer (wanted)
Feng Tan feng at lynxseismicdata.com
Mon Jul 25 10:29:59 EDT 2005
Hi, Makkus,
If I use my own user's root directory, the mirror site menu will show up, but
the following errors show up:
mkdir: cannot create directory `/usr/lib/R/library/00LOCK': Permission denied
ERROR: failed to lock directory '/usr/lib/R/library' for modifying
The downloaded packages are in
        /tmp/Rtmpny7325/downloaded_packages
Warning messages:
1: installation of package 'abind' had non-zero exit status in:
install.packages(c("sp", "rgdal", "maptools"), dependencies = TRUE)
2: installation of package 'pixmap' had non-zero exit status in:
3: installation of package 'RColorBrewer' had non-zero exit status in:
4: installation of package 'splancs' had non-zero exit status in:
5: installation of package 'sp' had non-zero exit status in:
6: installation of package 'maptools' had non-zero exit status in:
7: installation of package 'rgdal' had non-zero exit status in:
Thanks,
Feng
On Saturday 23 July 2005 02:04, Markus Neteler wrote:
> Hi Feng,
> I always launched update.packages() before installing the
> sp things. Then a Tcl window pops up where I select a mirror
> site.
> Or: probably you tcl/tk libraries are not installed [properly]?
> Markus
> On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
> > hi, Markus,
> > When I installing the R/GRASS6.0 interface using your instruction , the
> > following error showed:
> > > install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
> > --- Please select a CRAN mirror for use in this session ---
> > Error in inherits(x, "factor") : Object "res" not found
> > what happened?
> > Thanks,
> > Feng
> > On Thursday 21 July 2005 03:15, Markus Neteler wrote:
> > > [GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
> > > From:
> > > Markus Neteler
