[GRASSLIST:7708] Re: R Stats and GRASS primer (wanted)
    Jaime Carrera
    jaicarrerahdez at yahoo.com
    Mon Jul 25 12:44:33 EDT 2005
Hi Feng
It seems that you are not doing it as super user.
Change to SU mode; then start R and install.packages
HTH
Jaime
 --- Feng Tan <feng at lynxseismicdata.com> escribió:
> Hi, Makkus,
> If I use my own user's root directory, the mirror
> site menu will show up, but
> the following errors show up:
> mkdir: cannot create directory
> `/usr/lib/R/library/00LOCK': Permission denied
> ERROR: failed to lock directory '/usr/lib/R/library'
> for modifying
> for modifying
> for modifying
> for modifying
> for modifying
> for modifying
> for modifying
> The downloaded packages are in
>         /tmp/Rtmpny7325/downloaded_packages
> Warning messages:
> 1: installation of package 'abind' had non-zero exit
> status in:
> install.packages(c("sp", "rgdal", "maptools"),
> dependencies = TRUE)
> 2: installation of package 'pixmap' had non-zero
> exit status in:
> 3: installation of package 'RColorBrewer' had
> non-zero exit status in:
> 4: installation of package 'splancs' had non-zero
> exit status in:
> 5: installation of package 'sp' had non-zero exit
> status in:
> 6: installation of package 'maptools' had non-zero
> exit status in:
> 7: installation of package 'rgdal' had non-zero exit
> status in:
> Thanks,
> Feng
> On Saturday 23 July 2005 02:04, Markus Neteler
> wrote:
> > Hi Feng,
> > I always launched update.packages() before
> installing the
> > sp things. Then a Tcl window pops up where I
> select a mirror
> > site.
> > Or: probably you tcl/tk libraries are not
> installed [properly]?
> > Markus
> > On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan
> wrote:
> > > hi, Markus,
> > > When I installing the R/GRASS6.0 interface using
> your instruction , the
> > > following error showed:
> > > > install.packages(c("sp","rgdal","maptools"),
> dependencies=TRUE)
> > > --- Please select a CRAN mirror for use in this
> session ---
> > > Error in inherits(x, "factor") : Object "res"
> not found
> > > what happened?
> > > Thanks,
> > > Feng
> > > On Thursday 21 July 2005 03:15, Markus Neteler
> wrote:
> > > > [GRASSLIST:7657] Re: R Stats and GRASS primer
> (wanted)
> > > > From:
> > > > Markus Neteler
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
