[GRASSLIST:7693] Re: v.in.ascii
    David Kindem
    dkindem at chartermi.net
    Sat Jul 23 10:23:08 EDT 2005
I'm still struggling a bit with this.  I have a text file with the
following site information:
-85.74792719|42.98678484
I use v.in.ascii to generate a vector layer.  When I try to display
it in my location, I receive an error ("command not found").
If I set use g.region to set the region to match the vector layer, my
point displays.  Using g.where to identify the location, I get:
EAST:             NORTH:               LON:               LAT:
       -85.76293174        42.98644948       -91.48951223
0.00038771
So it seems that Grass is trying to interpret my decimal degree
locations as northing and easting data.  Does that seem to be the
case?  If so, do I need to include additional parameters in
v.in.ascii to get the software to recognize decimal degrees?
Thanks for any suggestions.
Dave
On Jul 18, 2005, at 2:35 AM, Hamish wrote:
> Dave:
>> I'm attempting to us v.in.ascii to import sites.  Things work fine
>> when I use Eastings/Northings.  However, I would like to import
>> points in latitude/longiture.  When I attempt to import positions
>> such as:
>> 85:46:05.14203W | 43:00:07.320715N
>> I receive the error message:
>> ERROR: x column is not of number type
>> Is there a way to have the program recognize lat./long as legitimate
>> entries?
> Ian:
>> Dave (or anyone else),
>> I was wondering if you ever found out how to import lat-long data
>> into
>> grass?  I would like to do the same thing.
> As it stands only numerical data can be used for x,y columns.
> It should be possible to change it to try G_scan_easting() and
> G_scan_northing() if a coordinate column is of type string, but it
> hasn't been done yet.
> You'll have to format the data as +/- DDD.DDDDDDD for now.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050723/59824969/attachment.html
