[GRASSLIST:7702] Re: v.in.ascii
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Mon Jul 25 01:18:43 EDT 2005
Dave I am not sure if this helps, but here are my thoughts. I hate to
say this but "command not found" sounds like a typo error to me (that
is what I tend to get a lot anyway). Check that you spelled everything
correctly.
Also, did you use v.in.ascii in a lat-long location, or in a
meter-based location (like UTM)? after running
g.region vect=your_vect -p
what are the results?
Also, what is the exact error when running d.vect your_vect?
Cheers,
Ian
On Jul 23, 2005, at 7:23 AM, David Kindem wrote:
> I'm still struggling a bit with this. I have a text file with the
> following site information:
> -85.74792719|42.98678484
> I use v.in.ascii to generate a vector layer. When I try to display it
> in my location, I receive an error ("command not found").
> If I set use g.region to set the region to match the vector layer, my
> point displays. Using g.where to identify the location, I get:
> EAST: NORTH: LON: LAT:
> -85.76293174 42.98644948 -91.48951223
> 0.00038771
> So it seems that Grass is trying to interpret my decimal degree
> locations as northing and easting data. Does that seem to be the
> case? If so, do I need to include additional parameters in v.in.ascii
> to get the software to recognize decimal degrees?
> Thanks for any suggestions.
> Dave
> On Jul 18, 2005, at 2:35 AM, Hamish wrote:
>> Dave:
>>> I'm attempting to us v.in.ascii to import sites. Things work fine
>>> when I use Eastings/Northings. However, I would like to import
>>> points in latitude/longiture. When I attempt to import positions
>>> such as:
>>> 85:46:05.14203W | 43:00:07.320715N
>>> I receive the error message:
>>> ERROR: x column is not of number type
>>> Is there a way to have the program recognize lat./long as legitimate
>>> entries?
>> Ian:
>>> Dave (or anyone else),
>>> I was wondering if you ever found out how to import lat-long data
>>> into
>>> grass? I would like to do the same thing.
>> As it stands only numerical data can be used for x,y columns.
>> It should be possible to change it to try G_scan_easting() and
>> G_scan_northing() if a coordinate column is of type string, but it
>> hasn't been done yet.
>> You'll have to format the data as +/- DDD.DDDDDDD for now.
>> Hamish
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050724/9d84f26a/attachment.bin
