[GRASSLIST:7720] Re: v.in.ascii
David Kindem
dkindem at chartermi.net
Tue Jul 26 07:05:24 EDT 2005
Ian,
As you suspected, I was trying to insert lat-long sites into a meter-
based location. I'm still pretty new at this, and have quite a bit
to learn.
Thanks for pointing me in the right direction.
Dave
On Jul 25, 2005, at 1:18 AM, Ian MacMillan wrote:
> Dave I am not sure if this helps, but here are my thoughts. I hate
> to say this but "command not found" sounds like a typo error to me
> (that is what I tend to get a lot anyway). Check that you spelled
> everything correctly.
> Also, did you use v.in.ascii in a lat-long location, or in a meter-
> based location (like UTM)? after running
> g.region vect=your_vect -p
> what are the results?
> Also, what is the exact error when running d.vect your_vect?
> Cheers,
> Ian
> On Jul 23, 2005, at 7:23 AM, David Kindem wrote:
>> I'm still struggling a bit with this. I have a text file with the
>> following site information:
>> -85.74792719|42.98678484
>> I use v.in.ascii to generate a vector layer. When I try to display
>> it in my location, I receive an error ("command not found").
>> If I set use g.region to set the region to match the vector layer,
>> my point displays. Using g.where to identify the location, I get:
>> EAST: NORTH: LON: LAT:
>> -85.76293174 42.98644948 -91.48951223
>> 0.00038771
>> So it seems that Grass is trying to interpret my decimal degree
>> locations as northing and easting data. Does that seem to be the
>> case? If so, do I need to include additional parameters in
>> v.in.ascii to get the software to recognize decimal degrees?
>> Thanks for any suggestions.
>> Dave
>> On Jul 18, 2005, at 2:35 AM, Hamish wrote:
>>> Dave:
>>>> I'm attempting to us v.in.ascii to import sites. Things work fine
>>>> when I use Eastings/Northings. However, I would like to import
>>>> points in latitude/longiture. When I attempt to import positions
>>>> such as:
>>>> 85:46:05.14203W | 43:00:07.320715N
>>>> I receive the error message:
>>>> ERROR: x column is not of number type
>>>> Is there a way to have the program recognize lat./long as
>>>> legitimate
>>>> entries?
>>> Ian:
>>>> Dave (or anyone else),
>>>> I was wondering if you ever found out how to import lat-long
>>>> data into
>>>> grass? I would like to do the same thing.
>>> As it stands only numerical data can be used for x,y columns.
>>> It should be possible to change it to try G_scan_easting() and
>>> G_scan_northing() if a coordinate column is of type string, but it
>>> hasn't been done yet.
>>> You'll have to format the data as +/- DDD.DDDDDDD for now.
>>> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050726/592844f0/attachment.html
