[GRASSLIST:7722] Re: importing with v.in.ascii into mysql db gives error
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Tue Jul 26 11:29:01 EDT 2005
Jason,
I am no positive about this, but I don't think you are allowed to have
the _ character in the database. It looks like it is reading your
column 'station_id' as just 'station', and then choking on the _
symbol. I can't remember for sure about this, but I think that you can
use '.' instead.
G'luck
-Ian
On Jul 26, 2005, at 7:17 AM, Jason Horn wrote:
> I have successfully set up mysql to store attribute data for several
> point coverages for my project. However when I use v.in.ascii to
> import new files, I get the following error:
> dbmi: Protocol error
> ERROR: Cannot describe table stations
> Does anyone know what this means? Below is the full text of the
> command I am using, and the error. The text file with the coordinates
> is properly formatted.
> GRASS 6.1.cvs (Texas_ll_WGS84):~ > cat coordinates.csv | v.in.ascii
> out=stations fs="," x=2 y=3 cat=1 columns='cat int, x double, y
> double, station_id varchar(10), name varchar(50), state varchar(10),
> elev int, height int, lat_deg int, lon_deg int'
> Maximum input row length: 78
> Maximum number of columns: 10
> Minimum number of columns: 10
> column: 1 type: integer
> column: 2 type: double
> column: 3 type: double
> column: 4 type: string length: 4
> column: 5 type: string length: 22
> column: 6 type: string length: 7
> column: 7 type: integer
> column: 8 type: integer
> column: 9 type: integer
> column: 10 type: integer
