[GRASSLIST:7724] Re: importing with v.in.ascii into mysql db gives error
Jason Horn
jhorn at bu.edu
Tue Jul 26 12:11:23 EDT 2005
Thanks Ian for the suggestion. I tried removing the "_" character
from column names, but no luck. I still get the error:
dbmi: Protocol error
ERROR: Cannot describe table stations
Thanks, though. It was a good thought.
On Jul 26, 2005, at 11:29 AM, Ian MacMillan wrote:
> Jason,
> I am no positive about this, but I don't think you are allowed to
> have the _ character in the database. It looks like it is reading
> your column 'station_id' as just 'station', and then choking on the
> _ symbol. I can't remember for sure about this, but I think that
> you can use '.' instead.
> G'luck
> -Ian
> On Jul 26, 2005, at 7:17 AM, Jason Horn wrote:
>> I have successfully set up mysql to store attribute data for
>> several point coverages for my project. However when I use
>> v.in.ascii to import new files, I get the following error:
>> Does anyone know what this means? Below is the full text of the
>> command I am using, and the error. The text file with the
>> coordinates is properly formatted.
>> GRASS 6.1.cvs (Texas_ll_WGS84):~ > cat coordinates.csv |
>> v.in.ascii out=stations fs="," x=2 y=3 cat=1 columns='cat int, x
>> double, y double, station_id varchar(10), name varchar(50), state
>> varchar(10), elev int, height int, lat_deg int, lon_deg int'
>> Maximum input row length: 78
>> Maximum number of columns: 10
>> Minimum number of columns: 10
>> column: 1 type: integer
>> column: 2 type: double
>> column: 3 type: double
>> column: 4 type: string length: 4
>> column: 5 type: string length: 22
>> column: 6 type: string length: 7
>> column: 7 type: integer
>> column: 8 type: integer
>> column: 9 type: integer
>> column: 10 type: integer
