[GRASSLIST:6974] Re: PS.MAP command -->overlay raster
Maciek Sieczka
werchowyna at epf.pl
Wed Jun 1 16:28:41 EDT 2005
Let me correct myself:
> Luca
> You could use r.patch. What is null in your overlay will be taken
> transparent and filled with your DTM. In order for the color tables to be
> preseved make sure that no same values are present in both your rasters -
> i.e. if your DTM is 1-1000 then recode your overlay to start at 1001.
> That will make your DTM hard-overlayed. An effect of semi-transparency you
> could achieve using r.his Your DTM should be the hue, overlay should be
> the intensity, saturation you can omit. Use r.composite to compose the
> output back into a color Grass layer and enjoy (slight lose of quality as
> "only" 32768 colors is a practical
> minimum
should be a "maximum" of course, sorry
> for Grass) or use 'rgb' command directly in ps.map (for best quality).
Maciek
