[GRASSLIST:7008] Re: calculating center of intensity
    Thomas Adams
    Thomas.Adams at noaa.gov
    Fri Jun  3 15:29:58 EDT 2005
Chuck,
Does this assume you only have one raster map cell shape? What if there
are multiples, which is what I think Jason has? I think, then, you would
get a single center of mass for the cluster of separate cells.
Tom
Charles Ehlschlaeger wrote:
> I don't have GRASS working on my computer to check this out, however,
> here is a procedure to calculating the center of a shape:
> Assume you have a raster map "shape" where the value of 0 is at all
> places w/out the shape and a positive value where the shape is located at.
> 1) Find the total volume of the shape w/:
> 1a) r.mapcalc command function:
> one = "1"
> 1b) r.volume d=shape clump=one
> (There should be a better way of doing this.)
> 2) Calculate volumeOnAxis of shape in North-South dimension with the
> r.mapcalc command:
> NSvolumeOn = shape * y()
> 3) Calculate massOnAxis of shape in East-West dimension with the
> r.mapcalc command:
> EWvolumeOn = shape * x()
> 4) Find the total volume of NSvolumeOn with:
> r.volume d= NSvolumeOn clump=one
> 5) Find the total volume of EWvolumeOn with:
> 6) The coordinates of the center will be
> east = total volume of EWvolumeOn / volume of shape
> north = total volume of NSvolumeOn / volume of shape
> A little csh and awk programming could replicate Idrisi's center program.
> <INSERT DISCLAIMERS ABOUT USING AT OWN RISK...>
> sincerely, chuck
> Markus Neteler wrote:
>>On Thu, Jun 02, 2005 at 03:42:36PM -0400, Jason Horn wrote:
>>>Does anyone know of a way to calculate the center of a shape in a
>>>raster file based on shape and pixel values?  For example, imagine a
>>>NEXRAD RADAR image showing a storm cloud.  Could GRASS be used to
>>>calculate the center of the cloud?  I'm not having any luck finding a
>>>grass raster function to do this.
>>I did a quick google search for
>> nexrad storm cell identification
>>or
>> nexrad  SCIT
>>which a couple of hits. Some programming might
>>be needed. I don't know if these algorithms are freely
>>available.
>>Markus
>Chuck Ehlschlaeger, Associate Professor & GIS Center Director
>Department  of  Geography,      Western  Illinois  University
>306C Tillman Hall,  1 University Circle,  Macomb,  IL   61455
>cre111 at wiu.edu,    phone: 309-298-1841,     fax: 309-298-3003
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050603/f9481373/attachment.html
