[GRASSLIST:7037] Re: calculating center of intensity
    Hamish
    hamish_nospam at yahoo.com
    Mon Jun  6 19:41:33 EDT 2005
> Ergo, I would expect the user to zoom to a region with a single rain
> event and mask out any areas they didn't consider part of that storm.
> Then, a variation of the procedure below would do the trick. As Hamish
> suggests, r.univar is probably better than r.volume.
Calculating the peak intensity is just a different method vs.
calculating center of mass; which one is "better" depends on the nature
of your data and what you are looking to do with it.
Hamish
