[GRASSLIST:7052] Re: calculating center of intensity
Thomas Adams
Thomas.Adams at noaa.gov
Tue Jun 7 08:04:48 EDT 2005
Chuck,
I pretty much figured that was the case. If Jason is doing what I think
he is doing, namely, to track storm cell life cycles & movement in order
to develop statistics and an algorithm for predictive purposes, he's
going to need to process a huge volume of data. So, the manual steps of
identifying individual cells and zooming in will be extremely tedious.
He needs something to automate the process.
BTW, last I remember (years ago), you moved to NYC -- so I guess you're
back in the midwest?
Regards,
Tom
Charles Ehlschlaeger wrote:
> Tom,
> I purposely threw in that caveat because I assumed that a human would
> have to decide what a storm pattern was. If an algorithm automatically
> found storm cells of contiguous positive rainfall values, there might
> be splinter cells a meteorologist would consider part of the same
> pattern. Ergo, I would expect the user to zoom to a region with a
> single rain event and mask out any areas they didn't consider part of
> that storm. Then, a variation of the procedure below would do the
> trick. As Hamish suggests, r.univar is probably better than r.volume.
> sincerely, chuck
> Thomas Adams wrote:
>> Chuck,
>> Does this assume you only have one raster map cell shape? What if
>> there are multiples, which is what I think Jason has? I think, then,
>> you would get a single center of mass for the cluster of separate cells.
>> Tom
>>> I don't have GRASS working on my computer to check this out,
>>> however, here is a procedure to calculating the center of a shape:
>>> Assume you have a raster map "shape" where the value of 0 is at all
>>> places w/out the shape and a positive value where the shape is
>>> located at.
>>> 1) Find the total volume of the shape w/:
>>> 1a) r.mapcalc command function:
>>> one = "1"
>>> 1b) r.volume d=shape clump=one
>>> (There should be a better way of doing this.)
>>> 2) Calculate volumeOnAxis of shape in North-South dimension with the
>>> r.mapcalc command:
>>> NSvolumeOn = shape * y()
>>> 3) Calculate massOnAxis of shape in East-West dimension with the
>>> r.mapcalc command:
>>> EWvolumeOn = shape * x()
>>> 4) Find the total volume of NSvolumeOn with:
>>> r.volume d= NSvolumeOn clump=one
>>> 5) Find the total volume of EWvolumeOn with:
>>> 6) The coordinates of the center will be
>>> east = total volume of EWvolumeOn / volume of shape
>>> north = total volume of NSvolumeOn / volume of shape
>>> A little csh and awk programming could replicate Idrisi's center
>>> program.
>>> <INSERT DISCLAIMERS ABOUT USING AT OWN RISK...>
>>> sincerely, chuck
>>> Markus Neteler wrote:
>>>>On Thu, Jun 02, 2005 at 03:42:36PM -0400, Jason Horn wrote:
>>>>>Does anyone know of a way to calculate the center of a shape in a
>>>>>raster file based on shape and pixel values? For example, imagine a
>>>>>NEXRAD RADAR image showing a storm cloud. Could GRASS be used to
>>>>>calculate the center of the cloud? I'm not having any luck finding a
>>>>>grass raster function to do this.
>>>>I did a quick google search for
>>>> nexrad storm cell identification
>>>>or
>>>> nexrad SCIT
>>>>which a couple of hits. Some programming might
>>>>be needed. I don't know if these algorithms are freely
>>>>available.
>>>>Markus
>>>Chuck Ehlschlaeger, Associate Professor & GIS Center Director
>>>Department of Geography, Western Illinois University
>>>306C Tillman Hall, 1 University Circle, Macomb, IL 61455
>>>cre111 at wiu.edu, phone: 309-298-1841, fax: 309-298-3003
>>Thomas E Adams
>>National Weather Service
>>Ohio River Forecast Center
>>1901 South State Route 134
>>Wilmington, OH 45177
>>EMAIL: thomas.adams at noaa.gov
>>VOICE: 937-383-0528
>>FAX: 937-383-0033
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050607/c7c8207d/attachment.html
