[GRASSLIST:7067] Re:
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Jun 7 16:10:52 EDT 2005
On Tue, 7 Jun 2005, Jason Horn wrote:
> This is an open question for Lorenzo:
> With the OSX build (using latest CVS version), how can you run g.region
> interactively from the prompt? It always opens a small window with options.
If you don't want the GUI Window to pop up, set the environment variable
GRASS_UI_TERM (to any value) and then you can use the parser interface.
But the old console-based "inter" version of g.region wasn't copied over
to 6.x AFAIK.
Paul
