[GRASSLIST:7098] Re: DXF to Grass dataset
RAVI KUMAR
ravivundavalli at yahoo.com
Thu Jun 9 08:34:23 EDT 2005
--- Hamish <hamish_nospam at yahoo.com> wrote:
> > Text drawn inside a polygon (inscribed text) in a
> DXF
> > file
> > Imported in GRASS should be taken as THE POLYGON'S
> > ATTRIBUTE
> > IS THIS POSSIBLE IN GRASS6 NOW?
> oh I see what you mean. They are vector lines shaped
> like letters - not
> text strings - embedded in the file. Knowing little
> about DXF, I'll go
> out on a limb and say that is hard to the point of
no.
> Did I understand correctly?
NO .. The are text and not lines drawn as text...
When U import a DXF file with a polygon
with an enclosed TEXT.. ARC-INFO makes the polygon
with THAT Text attribute..
IF THIS IS POSSIBLE IN grass THEN IT WILL QUICKEN
MAKING DIGITAL MAPS.
Ravi
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
