[GRASSLIST:7105] Re: DXF to Grass dataset
Nick Cahill
ndcahill at facstaff.wisc.edu
Thu Jun 9 23:32:20 EDT 2005
I think v.in.dxf was set up this way in Grass 3 or 4, wasn't it? You
would put a text object near a vector (contour line, etc.) and grass
would make this text the attribute of the imported vector.
Nick Cahill
On Jun 8, 2005, at 3:32 PM, RAVI KUMAR wrote:
> Hi Hamish,
> Text drawn inside a polygon (inscribed text) in a DXF
> file
> Imported in GRASS should be taken as THE POLYGON'S
> ATTRIBUTE
> IS THIS POSSIBLE IN GRASS6 NOW?
> If, S, may be i need to know some commands prompted.
> Thanks in anticipation
> Ravi
> --- Hamish <hamish_nospam at yahoo.com> wrote:
>>> WHY USE AUTOCAD AND WHY NOT DO THE ENTIRE THING IN
>>> GRASS??
>> why indeed.
>>> FOSS software 'Qcad', can be used instead of
>> AUTOCAD,
>>> and the CAD Draftsmen with limited knowledge can
>> make
>>> the vector of a geological map after scanning,
>> with
>>> inscribed text in each geological unit represented
>> as
>>> a polygon.
>>> If GRASS then can import the resultant DXF file
>> from
>>> Qcad, and make the inscribed text as its
>> attribute, it
>>> can speedup the process of making digital
>> datasets.
>>> Hope the GRASS program builders can give a
>> solution,
>>> like this.
>> You can use existing tools for the job. i.e. QGis's
>> grass vector
>> digitizer or 'v.digit bgcmd=d.rast ..'.
>> Hamish
> __________________________________
> Discover Yahoo!
> Use Yahoo! to plan a weekend, have fun online and more. Check it out!
> http://discover.yahoo.com/
