[GRASSLIST:7106] Re: DXF to Grass dataset
    RAVI KUMAR
    ravivundavalli at yahoo.com
    Fri Jun 10 01:33:26 EDT 2005
the import of DXF is not a problem and we have been doing it.
It is a WISH THAT
1. If the TEXT inside a polygon automatically becomes it's attribute after import into GRASS!!\\
It would save a lot of time.
May be the developers of GRASS may kindly consider this aspect.. in the next GRASS CVS release..
Ravi
Markus Neteler <neteler at itc.it> wrote:
I have tested the map with GRASS 6 (not knowing the
coordinate system):
v.in.dwg Geology.dxf out=geologydxf
MTEXT entity not supported
3555 elements processed
Building topology ...
3538 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 2581
Number of primitives: 3538
Number of points : 16
Number of lines : 3522
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
The database contains now:
v.db.select geologydxf
cat|entity_nam|color|weight|layer|block|txt
1|POINT|256|-1|TICS||
2|POINT|256|-1|TICS||
3|POINT|256|-1|TICS||
4|POINT|256|-1|TICS||
5|POINT|256|-1|TICS||
6|POINT|256|-1|TICS||
7|POINT|256|-1|TICS||
8|POINT|256|-1|TICS||
9|POINT|256|-1|TICS||
10|POINT|256|-1|TICS||
11|POINT|256|-1|TICS||
12|POINT|256|-1|TICS||
13|POINT|256|-1|TICS||
14|POINT|256|-1|TICS||
15|POINT|256|-1|TICS||
16|POINT|256|-1|TICS||
17|LINE|256|-1|GELI236||
18|LINE|256|-1|GELI236||
19|LINE|256|-1|GELI236||
20|LINE|256|-1|GELI236||
21|LINE|256|-1|GELI236||
22|LINE|256|-1|GELI236||
23|LINE|256|-1|GELI236||
24|LINE|256|-1|GELI236||
3536|LINE|256|-1|GELI236||
3537|LINE|256|-1|GELI236||
3538|LINE|256|-1|GELI236||
I don't know if this is what you expected but to some extent
you can import the DXF file.
Regards
Markus Neteler
On Thu, Jun 09, 2005 at 05:57:04AM -0700, RAVI KUMAR wrote:
> Hi,
> Iam attaching a small 1:50000 scale geological map,
> which is scanned and vectorised manually by a
> draftsman.
> When this is imported into ARC-INFO, the inscribed
> text in each Geological polygon becomes its attribute.
> This is a very quick method,
> 1. where all the digitization is done by the not so
> computer savvy draftsmen
> 2. Then the Geologist imports it into ARC-INFO to
> convert into a digital data with a vital link
> attribute.
> 3. The geologist then attaches an external database
> table using this link attribute.
> If U can make such a thing possible in grass, then we
> can use OGLed Qcad on linux, for the draftsmen and
> GRASS for the Geologists.
> Ravi
> --- Markus Neteler wrote:
> > Hi Ravi,
> > could you send (offlist) a small DXF sample file to
> > me?
> > Then I can check for the attributes in v.in.dwg.
> > Markus
> > On Wed, Jun 08, 2005 at 04:56:51AM -0700, RAVI KUMAR
> > wrote:
> > > Hi All,
> > > recently we completed a Geological digital dataset
> > in
> > > ARC-INFO.
> > > The steps in short are
> > > 1. SCAN the map into and image
> > > 2. Draw polygons of various geological units with
> > the
> > > image of the map in the background (using Autocad)
> > > 3. The polygons of individual units have an
> > inscribed
> > > text indicating the geology and save as a DXF file
> > > 4. Import the resultant DXF file into ARC-INFO.
> > > 5. ARC-INFO automaticall takes the inscribed text
> > in
> > > each polygon as an attribute for that polygon.
> > > Using DXF import software GRASS is able to get all
> > the
> > > vectors, but IF THE INSCRIBED TEXT OF EACH POLYGON
> > > BECOMES AN ATTRIBUTE then it will be far simpler
> > to
> > > make a GRASS dataset.
> > > WHY USE AUTOCAD AND WHY NOT DO THE ENTIRE THING IN
> > > GRASS??
> > > FOSS software 'Qcad', can be used instead of
> > AUTOCAD,
> > > and the CAD Draftsmen with limited knowledge can
> > make
> > > the vector of a geological map after scanning,
> > with
> > > inscribed text in each geological unit represented
> > as
> > > a polygon.
> > > If GRASS then can import the resultant DXF file
> > from
> > > Qcad, and make the inscribed text as its
> > attribute, it
> > > can speedup the process of making digital
> > datasets.
> > > Hope the GRASS program builders can give a
> > solution,
> > > like this.
> > > Thanking in anticipation
> > > Ravi
> > > __________________________________
> > > Do you Yahoo!?
> > > Yahoo! Mail - Find what you need with new enhanced
> > search.
> > > http://info.mail.yahoo.com/mail_250
> > Markus Neteler
> > http://mpa.itc.it
> > ITC-irst - Centro per la Ricerca Scientifica e
> > Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data
> > Analysis
> > Via Sommarive, 18 - 38050 Povo
> > (Trento), Italy
> Discover Yahoo!
> Use Yahoo! to plan a weekend, have fun online and more. Check it out!
> http://discover.yahoo.com/
Markus Neteler http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Discover Yahoo!
 Find restaurants, movies, travel & more fun for the weekend. Check it out!
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050609/2ea32442/attachment.html
