[GRASSLIST:7212] Re: Mapset Access
Fri Jun 17 13:55:20 EDT 2005
David Orme wrote:
> Am I right in thinking that:
> - the mapsets marked with a plus if you use 'mapset: list' on startup
> are simply those which you own.
Almost; it indicates the you own the mapset and no .lock file is
present in the mapset directory.
> - g.access simply controls whether other users can see anything
> within a mapset you own (and hence whether they can use
> mymap at mymapset, or mymap following g.mapsets)
Correct.
