[GRASSLIST:7218] Compile Errors continue in 6.0.0
Thomas Colson
tom_colson at ncsu.edu
Fri Jun 17 21:49:18 EDT 2005
Ok, thanks for the tip.
Starting fresh again, on ANOTHER machine.
installed fftw 2.1.5 using -g -O2 -fPIC -D_FILE_OFFSET_BITS=64
The fftw test work fine..
Installed gdal
gdalinfo --version
GDAL 1.2.5.0, released 2004/11/22
tcl/tk 8.4.9, proj4.4.9
reran ldconfig, libgdal.so.1 is in usr/local/lib,
gcc -dumpversion
4.0.0
gcc -dumpmachine
x86_64-redhat-linux (Fedora Core 4)
Same errors! On make (Grass 6.0.0) I get:
Errors in:
/grass/grass-6.0.0/lib/gmath
/grass/grass-6.0.0/lib/imagery
/grass/grass-6.0.0/lib/rst/interp_float
/grass/grass-6.0.0/imagery/i.class
/grass/grass-6.0.0/imagery/i.cluster
/grass/grass-6.0.0/imagery/i.gensig
/grass/grass-6.0.0/imagery/i.gensigset
/grass/grass-6.0.0/imagery/i.group
/grass/grass-6.0.0/imagery/i.his.rgb
/grass/grass-6.0.0/imagery/i.maxlik
/grass/grass-6.0.0/imagery/i.ortho.photo/libes
/grass/grass-6.0.0/imagery/i.ortho.photo/menu
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.2image
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.2target
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.camera
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.elev
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.init
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.rectify
/grass/grass-6.0.0/imagery/i.ortho.photo/photo.target
/grass/grass-6.0.0/imagery/i.points
/grass/grass-6.0.0/imagery/i.rectify
/grass/grass-6.0.0/imagery/i.rgb.his
/grass/grass-6.0.0/imagery/i.smap/shapiro
/grass/grass-6.0.0/imagery/i.target
/grass/grass-6.0.0/imagery/i.vpoints
/grass/grass-6.0.0/imagery/i.cca
/grass/grass-6.0.0/imagery/i.fft
/grass/grass-6.0.0/imagery/i.ifft
/grass/grass-6.0.0/imagery/i.pca
/grass/grass-6.0.0/imagery/i.zc
/grass/grass-6.0.0/ps/ps.map
/grass/grass-6.0.0/raster/r.grow2
/grass/grass-6.0.0/raster/r.param.scale
/grass/grass-6.0.0/raster/r.resamp.rst
/grass/grass-6.0.0/raster/r.in.gdal
/grass/grass-6.0.0/raster/r.surf.fractal
/grass/grass-6.0.0/raster/r.surf.gauss
/grass/grass-6.0.0/raster/r.surf.random
/grass/grass-6.0.0/vector/v.kernel
/grass/grass-6.0.0/vector/v.surf.rst
and:
cd gmath
make
gcc -I/grass/grass-6.0.0/include
-I/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/include/grass -g -O2
-Wall -Wconversion -Wno-implicit-int -fPIC -DPACKAGE=\""grasslibs"\"
-DPACKAGE=\""grasslibs"\" -I/grass/grass-6.0.0/include
-I/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/include/grass \
-o OBJ.x86_64-unknown-linux-gnu/del2g.o -c del2g.c
In file included from del2g.c:23:
numerical.h:47: error: array type has incomplete element type
del2g.c: In function del2g:
del2g.c:34: warning: passing argument 1 of G_malloc with different width
due to prototype
del2g.c:35: warning: passing argument 1 of G_malloc with different width
due to prototype
make: *** [OBJ.x86_64-unknown-linux-gnu/del2g.o] Error 1
and:
cd ps
make
make[1]: Entering directory `/grass/grass-6.0.0/ps/ps.map'
gcc -Wl,--export-dynamic
-L/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/lib
-I/usr/local/include -DPACKAGE=\""grassmods"\" -o
/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/bin/ps.map
OBJ.x86_64-unknown-linux-gnu/box.o
OBJ.x86_64-unknown-linux-gnu/chk_scale.o
OBJ.x86_64-unknown-linux-gnu/comment.o
OBJ.x86_64-unknown-linux-gnu/distance.o
OBJ.x86_64-unknown-linux-gnu/do_geogrid.o
OBJ.x86_64-unknown-linux-gnu/do_grid.o
OBJ.x86_64-unknown-linux-gnu/do_header.o
OBJ.x86_64-unknown-linux-gnu/do_labels.o
OBJ.x86_64-unknown-linux-gnu/do_masking.o
OBJ.x86_64-unknown-linux-gnu/do_plt.o
OBJ.x86_64-unknown-linux-gnu/do_psfiles.o
OBJ.x86_64-unknown-linux-gnu/do_scalebar.o
OBJ.x86_64-unknown-linux-gnu/do_vectors.o
OBJ.x86_64-unknown-linux-gnu/eps.o OBJ.x86_64-unknown-linux-gnu/error.o
OBJ.x86_64-unknown-linux-gnu/fit_map.o
OBJ.x86_64-unknown-linux-gnu/get_font.o
OBJ.x86_64-unknown-linux-gnu/getgrid.o
OBJ.x86_64-unknown-linux-gnu/get_scalebar.o
OBJ.x86_64-unknown-linux-gnu/gprims.o OBJ.x86_64-unknown-linux-gnu/input.o
OBJ.x86_64-unknown-linux-gnu/key_data.o
OBJ.x86_64-unknown-linux-gnu/main.o
OBJ.x86_64-unknown-linux-gnu/makeprocs.o
OBJ.x86_64-unknown-linux-gnu/map_info.o
OBJ.x86_64-unknown-linux-gnu/map_setup.o
OBJ.x86_64-unknown-linux-gnu/mtextbox.o
OBJ.x86_64-unknown-linux-gnu/outl_io.o
OBJ.x86_64-unknown-linux-gnu/parse_list.o
OBJ.x86_64-unknown-linux-gnu/ps_clrtbl.o
OBJ.x86_64-unknown-linux-gnu/ps_colors.o
OBJ.x86_64-unknown-linux-gnu/ps_fclrtbl.o
OBJ.x86_64-unknown-linux-gnu/ps_header.o
OBJ.x86_64-unknown-linux-gnu/ps_map.o
OBJ.x86_64-unknown-linux-gnu/ps_outline.o
OBJ.x86_64-unknown-linux-gnu/ps_raster.o
OBJ.x86_64-unknown-linux-gnu/ps_vareas.o
OBJ.x86_64-unknown-linux-gnu/ps_vlegend.o
OBJ.x86_64-unknown-linux-gnu/ps_vlines.o
OBJ.x86_64-unknown-linux-gnu/ps_vpoints.o
OBJ.x86_64-unknown-linux-gnu/r_cell.o
OBJ.x86_64-unknown-linux-gnu/r_colortable.o
OBJ.x86_64-unknown-linux-gnu/read_cfg.o
OBJ.x86_64-unknown-linux-gnu/r_group.o
OBJ.x86_64-unknown-linux-gnu/r_header.o
OBJ.x86_64-unknown-linux-gnu/r_info.o
OBJ.x86_64-unknown-linux-gnu/r_labels.o
OBJ.x86_64-unknown-linux-gnu/r_paper.o
OBJ.x86_64-unknown-linux-gnu/r_plt.o OBJ.x86_64-unknown-linux-gnu/r_rgb.o
OBJ.x86_64-unknown-linux-gnu/r_text.o
OBJ.x86_64-unknown-linux-gnu/r_vareas.o
OBJ.x86_64-unknown-linux-gnu/r_vlegend.o
OBJ.x86_64-unknown-linux-gnu/r_vlines.o
OBJ.x86_64-unknown-linux-gnu/r_vpoints.o
OBJ.x86_64-unknown-linux-gnu/r_wind.o OBJ.x86_64-unknown-linux-gnu/scale.o
OBJ.x86_64-unknown-linux-gnu/scan_gis.o
OBJ.x86_64-unknown-linux-gnu/scan_misc.o
OBJ.x86_64-unknown-linux-gnu/scan_ref.o
OBJ.x86_64-unknown-linux-gnu/session.o
OBJ.x86_64-unknown-linux-gnu/show_scale.o
OBJ.x86_64-unknown-linux-gnu/symbol.o
OBJ.x86_64-unknown-linux-gnu/textbox.o OBJ.x86_64-unknown-linux-gnu/vect.o
OBJ.x86_64-unknown-linux-gnu/vector.o OBJ.x86_64-unknown-linux-gnu/yesno.o
-lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm
-lgrass_dbmiclient -lgrass_dbmibase -L/usr/local/lib -lgdal -lgrass_gproj
-lproj -L/usr/local/lib -lgdal -lgrass_symb -lgrass_gis -lgrass_datetime
-lz -lgrass_datetime -lgrass_I -lgrass_vask -lncurses -lbsd-compat
-lgrass_gmath -lfftw -lm -lm -lz
/usr/bin/ld: cannot find -lgrass_I
collect2: ld returned 1 exit status
make[1]: *** [/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/bin/ps.map]
Error 1
make[1]: Leaving directory `/grass/grass-6.0.0/ps/ps.map'
I'm assuming that the failed build of gmath is creating all the other
errors? What could be causing this? Is there anywork around to getting
these libraries to build somehow?
> Thomas Colson wrote:
>> Yeah, I kinda figured that a great deal of stuff wasn't being built as
>> it
>> should. So how do you correct the error on the stuff that should be
>> built,
>> but isn't being built? How can an "out of box" install of Grass6 on a
>> new
>> install of Fedora have so many library problems? I'd like to think I
>> spent
>> a great deal of time making sure all the correct versions of the
>> dependancies were installed prior to the grass build, but it seems like
>> there are some undocumented secret dependancies....
>> some libraries did't build, so anything that needs them will fail.
>> cd lib/gmath
>> make
>> gcc -shared -o
>> /grass6/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.6.1.cvs.so
> [snip]
>> /usr/bin/ld: /usr/local/lib/libfftw.a(fftwnd.o): relocation R_X86_64_32
>> against `a local symbol' can not be used when making a shared object;
>> recompile with -fPIC
> It appears that /usr/local/lib/libfftw.a has been built without the
> -fPIC switch, which means that it can only be linked directly into an
> executable, not into a shared library. GRASS needs FFTW to be usable
> by shared libraries.
> Can FFTW be built as a shared library on x86-64? That would be the
> simplest solution. Otherwise try adding -fPIC when building FFTW, e.g.
> CFLAGS='-g -02 -fPIC' ./configure ...
> Glynn Clements <glynn at gclements.plus.com>
Thomas Colson
Center For Earth Observation
North Carolina State University
Raleigh, NC
(919)515 3434
(919)673 8023
