[GRASSLIST:7222] Re: Compile Errors continue in 6.0.0
Sat Jun 18 04:11:35 EDT 2005
Thomas Colson wrote:
> cd gmath
> make
> gcc -I/grass/grass-6.0.0/include
> -I/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/include/grass  -g -O2
> -Wall -Wconversion -Wno-implicit-int   -fPIC    -DPACKAGE=\""grasslibs"\"
>     -DPACKAGE=\""grasslibs"\"  -I/grass/grass-6.0.0/include
> -I/grass/grass-6.0.0/dist.x86_64-unknown-linux-gnu/include/grass \
>         -o OBJ.x86_64-unknown-linux-gnu/del2g.o -c del2g.c
> In file included from del2g.c:23:
> numerical.h:47: error: array type has incomplete element type
Odd.
Try removing the following lines from lib/gmath/numeric.h:
	/* jacobi.c */
	#define MC 50
	extern char outputfile[50];
	extern char groupname[50], subgroup[50], signame[50];
These declarations don't appear to be used anywhere. They probably
relate to having extracted the code in jacobi.c from elsewhere.
> I'm assuming that the failed build of gmath is creating all the other
> errors?
Probably.
> What could be causing this?
The above error regarding line 47 of numerical.h. line 47 appears
empty, but the jacobi.c section is the closest match,
> Is there anywork around to getting these libraries to build somehow?
Eliminate the numerical.h error.
