[GRASSLIST:7326] Re: The bounding box of the map outside current region
Maciek Sieczka
werchowyna at epf.pl
Mon Jun 27 16:39:54 EDT 2005
Atif
Plaese 'Reply to All' so that the message goes to list archive and other
folks can also help or make use of our conversation.
> Hello Maciek, thank you. You are correc. They do not match.
> How do I go about matching the region extent?
Are you sure they cover the same area? Are they in the same projection? How
did you get your layers into Grass? What do the v.info and r.info say?
> Maciek Sieczka wrote:
>> Atif
>> I guess that your vector layer doesn't fit your raster layer. Try
>> "g.region vect=c2405_3 -p" and "g.region rast=2405-3.1 -p" to check
>> whether the region extent in both cases is the same.
>> Maciek
>> ----- Original Message ----- From: "Atif Rajan"
>>> Dear Reader,
>>> I am attempting overlay a vector map on a raster GEO TIFF
>>> On setting the region ( g.region rast=2405-3.1) and then displaying the
>>> raster
>>> map, the raster comes up fine on the graphics display.
>>> However, attempting to display the vector map (d.vect c2405_3),
>>> the following message appears:
>>> " The bounding box of the map outside current region, nothing displayed"
>>> Any words of wisdon as to what I am doing incorrectly or not doing for
>>> that
>>> matter?
>>> Thank you.
>>> Atif Rajan
