[GRASSLIST:7342] Re: Wish GRASS-News was HTML in addition to PDF
Markus Neteler neteler at itc.it
Tue Jun 28 10:37:18 EDT 2005
I have added a 'html' target into the Vol3 Newsletter Makefile.
Running
 make html
will run 'latex2html' (must be installed of course) and creates
the newsletter in HTML. Some fine tuning might be needed, though.
I have also added an 'ascii' target into the Vol3 Newsletter Makefile.
Running
 make ascii
will run 'detex' (modify to use your preferred software) to extract
ASCII text from the original Latex files.
Cheers
 Markus
On Mon, Jun 27, 2005 at 09:55:32AM +0200, Martin Wegmann wrote:
> hello Dan,
> you can get the latex source from the cvs repository, please feel free to grap
> it. However due to the Latex commands it will be cumbersome to read.
> The actual articles can be found in Bivand.tex, Bowman_srtm.tex etc.
> I can send you the tex files (without images), they would be around 200 Kb.
> I would be very happy if you give latextohtml (as Hamish proposed) or
> hyperlatex a try. I tried it but had no luck with an appropriate html output
> yet.
> Martin
> On Sunday 26 June 2005 02:18, you wrote:
> > Well, I'm back from my query into how to just read the text parts of
> > the newsletter for modem users who are used to e.g., getting .html
> > without images.
> > >>>>> "T" == Thomas Arendsen Hein <... intevation.de> writes:
> > T> * Dan Jacobson <jidanni at jidanni.org> [20050623 22:00]:
> > >> >> $ wget --spider -Y off -S
> > >> >> http://freegis.org/cgi-bin/viewcvs.cgi/newsletter/GRASSNews_vol3/GRAS
> > >> >>Snews_vol3.tex
> > >> >> 'http://freegis.org/cgi-bin/viewcvs.cgi/newsletter/GRASSNews_vol3/GRA
> > >> >>SSNews_vol3.tar.gz?tarball=1'
> > >> [Failed, server doesn't support HEAD]
> > >> I was trying to get some idea of how big they were before I download.
> > >> Perhaps you can tell me.
> > T> The first one is not the real file, but the changelog.
> > T> The tarball from the second link will be 6.5 MB.
> > So we see however one looks at it, it will be megabytes before one can
> > get his hands on any text.
> Martin Wegmann
> DLR - German Aerospace Center
> German Remote Sensing Data Center
> Dept.of Geography
> Remote Sensing and Biodiversity Unit
> University of Wuerzburg
> Am Hubland
> 97074 Würzburg
> phone: +49-(0)931 - 888 4797
> fax:   +49-(0)931 - 888 4961
> http://www.biota-africa.org
> http://www.biogis.de
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
