[GRASSLIST:7352] Re: grass has been running for three days
Massimiliano Cannata massimiliano.cannata at supsi.ch
Tue Jun 28 14:24:55 EDT 2005
prcessing very large maps is quite slow with r.whatershed (I guess you
are using this command!).
I suggest to give a try to r.terraflow, it has been created for large
raster file processing....
Hope this help.
Maxi
orkun wrote:
> hello
> grass has been running for three days to create watershed related maps.
> At this moment, it has been in this stage for a long time (almost one
> day):
> Running: /usr/lib/grass/etc/water/ram el="el_5" t=100 se="str_5"
> ha="hbas20_50"
> SECTION 1a (of 5): Initiating Memory.
> SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
> SECTION 2: A * Search.                      Percent complete:
> SECTION 3: Accumulating Surface Flow.       Percent complete:
> SECTION 4: Watershed determination.
> SECTION 5: Closing Maps.
> I am not sure if  grass will be able to complete it's job ?
> or
> is it a good idea to cancel the job and start again with smaller region?
> what do you suggest ?
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
Type: application/defanged
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050628/1d55f7ca/massimiliano.cannata.bin
