[GRASSLIST:7361] Re: grass has been running for three days
orkun
temiz at deprem.gov.tr
Wed Jun 29 02:41:16 EDT 2005
Massimiliano Cannata wrote:
> prcessing very large maps is quite slow with r.whatershed (I guess you
> are using this command!).
> I suggest to give a try to r.terraflow, it has been created for large
> raster file processing....
> Hope this help.
> Maxi
> orkun wrote:
>> hello
>> grass has been running for three days to create watershed related maps.
>> At this moment, it has been in this stage for a long time (almost one
>> day):
>> Running: /usr/lib/grass/etc/water/ram el="el_5" t=100 se="str_5"
>> ha="hbas20_50"
>> SECTION 1a (of 5): Initiating Memory.
>> SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
>> SECTION 2: A * Search. Percent complete:
>> SECTION 3: Accumulating Surface Flow. Percent complete:
>> SECTION 4: Watershed determination.
>> SECTION 5: Closing Maps.
>> I am not sure if grass will be able to complete it's job ?
>> or
>> is it a good idea to cancel the job and start again with smaller region?
>> what do you suggest ?
>> regards
>> Ahmet Temiz
>> ______________________________________
>> XamimeLT - installed on mailserver for domain @deprem.gov.tr
>> Queries to: postmaster at deprem.gov.tr
>> The views and opinions expressed in this e-mail message are the
>> sender's own
>> and do not necessarily represent the views and the opinions of
>> Earthquake Research Dept.
>> of General Directorate of Disaster Affairs.
>> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
>> olarak T.C.
>> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
>> nitelikte degildir.
thank you
as far as I see r.terraflow does not produce half basin.
I need a module that creates half basin other than r.watershed.
regards
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
