[GRASSLIST:7362] Re: [bug #3112] grass has been running for three
days
Hamish
hamish_nospam at yahoo.com
Wed Jun 29 03:15:52 EDT 2005
> >> grass has been running for three days to create watershed related
> >> maps.
> >> At this moment, it has been in this stage for a long time (almost
> >> one day):
> >> Running: /usr/lib/grass/etc/water/ram el="el_5" t=100 se="str_5"
> >> ha="hbas20_50"
> >> SECTION 1a (of 5): Initiating Memory.
> >> SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
> >> SECTION 2: A * Search. Percent complete:
> >> SECTION 3: Accumulating Surface Flow. Percent complete:
> >> SECTION 4: Watershed determination.
> >> SECTION 5: Closing Maps.
> >> I am not sure if grass will be able to complete it's job ?
> >> or is it a good idea to cancel the job and start again with
> >> smaller region?
> >> what do you suggest ?
> > prcessing very large maps is quite slow with r.whatershed (I guess
> > you are using this command!).
> as far as I see r.terraflow does not produce half basin.
> I need a module that creates half basin other than r.watershed.
Looks like the while loop in raster/r.watershed/ram/close_maps2.c
line 38 is never satisfied.
Maybe same endless call to close_array_seg() is what causes bug #3112?
Things often report 98% when actually done as G_percent() is often
called in the wrong place or doesn't get called after exit. (e.g. watch
r.terrflow run) So it is likely it finished & then got stuck on the
cleanup step.
-- how big is the test region?
-- r.info: CELL map, DCELL map?
(idea- try a CELL version [r.mapcalc 'newmap=int(oldmap)'])
that's about as deep as I can look into it right now.
Hamish
