[GRASSLIST:7368] Re: r.support
    Glynn Clements
    glynn at gclements.plus.com
    Wed Jun 29 08:00:44 EDT 2005
Michael Fecht wrote:
> I have imported landsat images (.bsq) via r.in.gdal to grass6 (prj:
> Austrian Lambert Confomal Conic Projection). Although the image has a
> bqw-worldfile it is not refereneced correctly.
> In a next step I tried with  grass5.4 .  After importing  the image
> there was the same result, but it was possible to adjust the region of
> the raster using r.support.
> I read that r.support is not necessary in grass6 anymore. But how can I
> modify the header of a raster in grass6? Has some one a solution for that?
You can change the region with r.region.
