[GRASSLIST:7369] Re: r.support
Michael Fecht michael.fecht at uibk.ac.at
Wed Jun 29 08:28:54 EDT 2005
Glynn Clements wrote:
>Michael Fecht wrote:
>>I have imported landsat images (.bsq) via r.in.gdal to grass6 (prj:
>>Austrian Lambert Confomal Conic Projection). Although the image has a
>>bqw-worldfile it is not refereneced correctly.
>>In a next step I tried with  grass5.4 .  After importing  the image
>>there was the same result, but it was possible to adjust the region of
>>the raster using r.support.
>>I read that r.support is not necessary in grass6 anymore. But how can I
>>modify the header of a raster in grass6? Has some one a solution for that?
>You can change the region with r.region.
Thanks.
Michael Fecht
Freisingstraße 2
A6020 Innsbruck
+43 (0)650 8131923
