[GRASSLIST:6002] Re: Concurrent use of GRASS
Fri Mar 4 03:35:05 EST 2005
Hamish wrote:
> > I have a dual CPU machine, and I would like to run several GRASS
> > programs in parallel. I found that since I need to change regions, I
> > end up having race conditions, and endless grief. I would rather just
> > use two different GRASS sessions to do things (maybe with a different
> > location). However, GRASS complains that
> > ${USER} is currently running GRASS 5.4.0. Concurrent use not allowed.
> Concurrent use of GRASS is only supported in version 6.0.
> Even then, each session must use a different location. (but of course
> you can who two locations which are twins and copy over the processed
> results)
You should be able to use different mapsets within the same location.
