[GRASSLIST:6041] RE: Grass - Redhat
Christian Ferreira
christian.grass at gmail.com
Mon Mar 7 11:43:28 EST 2005
Ravi,
In addition to what Craig said, I suggest to you that also test
packages from Fedora (the free version of Red Hat now). Because Red
Hat is now based on Fedora. It's basically the same thing. Fedora is a
experimental ground for features that Red Hat is planning for its
commercial/enterprise versions of Linux.
Cheers.
Christian S. Ferreira
On Mon, 07 Mar 2005 09:32:18 -0700, Craig Aumann <caumann at ualberta.ca> wrote:
> I just used the Mandrake ones. When installing, I first used
> rpm -Uvh --test libproj0*.*.rpm etc...
> to make sure there aren't any problems.
> I personally don't know why these don't exist for RedHat, as there are a
> lot more RedHat users than Mandrake generally.
> Cheers!
> Craig
> Sun, 2005-03-06 at 21:59, RAVI KUMAR wrote:
> > Craig
> > thanQ for the info. Pl let me know where I can find
> > the RPMs for redhat. I tried on RPMfind.net but for
> > redhat it drew a blank.
> > Pl let me know the website where I can down load the
> > following rpms for REDHAT (listed below which are for
> > mandrake found on RPMfind.net).
> > libproj0-4.4.8-1mdk.i586.rpm
> > xterm-196-1mdk.i586.rpm
> > libgrass5_0-1.0.0-1mdk.i586.rpm
> > libgdal0-1.1.9-2mdk.i586.rpm
> > libgdal1-1.2.2-1mdk.i586.rpm
> > libfftw2-2.1.5-3mdk.i586.rpm
> > libogdi-3.1.2-1mdk.i586.rpm
> > libgeotiff1-1.2.2-2mdk.i586.rpm
> > libstdc++6-3.4.1-4mdk.i586.rpm
> > tk-8.3.3-74asp.i386.rpm
> > tcl-8.3.3-74.i386.rpm
> > Ravi
> > --- Craig Aumann <caumann at ualberta.ca> wrote:
> > > I actually use RedHat WS 3.0 and Grass 6.0. I had
> > > greater success
> > > installing 6.0 from the Development Binaries than
> > > trying to use the RPM
> > > packages (see the bottom of the download page). You
> > > should be able to
> > > find the any required packages listed to run the
> > > binary on rpmfind.net.
> > > Hope that helps.
> > __________________________________
> > Celebrate Yahoo!'s 10th Birthday!
> > Yahoo! Netrospective: 100 Moments of the Web
> > http://birthday.yahoo.com/netrospective/
