[GRASSLIST:6039] RE: Grass - Redhat
Craig Aumann
caumann at ualberta.ca
Mon Mar 7 11:32:18 EST 2005
I just used the Mandrake ones. When installing, I first used
rpm -Uvh --test libproj0*.*.rpm etc...
to make sure there aren't any problems.
I personally don't know why these don't exist for RedHat, as there are a
lot more RedHat users than Mandrake generally.
Cheers!
Craig
Sun, 2005-03-06 at 21:59, RAVI KUMAR wrote:
> Craig
> thanQ for the info. Pl let me know where I can find
> the RPMs for redhat. I tried on RPMfind.net but for
> redhat it drew a blank.
> Pl let me know the website where I can down load the
> following rpms for REDHAT (listed below which are for
> mandrake found on RPMfind.net).
> libproj0-4.4.8-1mdk.i586.rpm
> xterm-196-1mdk.i586.rpm
> libgrass5_0-1.0.0-1mdk.i586.rpm
> libgdal0-1.1.9-2mdk.i586.rpm
> libgdal1-1.2.2-1mdk.i586.rpm
> libfftw2-2.1.5-3mdk.i586.rpm
> libogdi-3.1.2-1mdk.i586.rpm
> libgeotiff1-1.2.2-2mdk.i586.rpm
> libstdc++6-3.4.1-4mdk.i586.rpm
> tk-8.3.3-74asp.i386.rpm
> tcl-8.3.3-74.i386.rpm
> Ravi
> --- Craig Aumann <caumann at ualberta.ca> wrote:
> > I actually use RedHat WS 3.0 and Grass 6.0. I had
> > greater success
> > installing 6.0 from the Development Binaries than
> > trying to use the RPM
> > packages (see the bottom of the download page). You
> > should be able to
> > find the any required packages listed to run the
> > binary on rpmfind.net.
> > Hope that helps.
> __________________________________
> Celebrate Yahoo!'s 10th Birthday!
> Yahoo! Netrospective: 100 Moments of the Web
> http://birthday.yahoo.com/netrospective/
