[GRASSLIST:6043] Re: How deep is a region?
Roger Bivand Roger.Bivand at nhh.no
Mon Mar 7 12:11:35 EST 2005
On Mon, 7 Mar 2005, Radim Blazek wrote:
> I see, r.in.gdal was fixed after beta2, should be ok in cvs, just edit
> the DEFAULT_WIND and change depths to 1.
Reading the CVS shows include/gis.h struct Cell_head has int depths, the
changes in raster/r.in.gdal/main.c are setting cellhd.depths = 1.5; - why
should this work? And why 1.5 when the top is 1.0, bottom 0.0, and
resolution 1.0, all doubles? Shouldn't it just be (int) 1?
Roger
> Radim
> dpadam wrote:
> > It was created using r.in.gdal; I haven't been able to do anything further
> > because of the "invalid region" errors.
> > david
> > ---------- Original Message -----------
> > From: Radim Blazek <blazek at itc.it>
> > To: David Adam <david at quercus.org>
> > Cc: grasslist at baylor.edu
> > Sent: Mon, 07 Mar 2005 09:39:52 +0100
> > Subject: Re: [GRASSLIST:6019] Re: How deep is a region?
> >>How was the region file created - what was the last module which
> >>modified the region?
> >>Radim
> >>David Adam wrote:
> >>>Hamish wrote:
> >>>>>I'm trying to set up a region, starting with a Landsat TIFF
> >>>>>image from California.  I have imported the region with r.in.gdal,
> >>>>>which produces a large file. I then close grass60 and reopen in the
> >>>>>new location, at which point I get the errors
> >>>>>GRASS_INFO_ERROR(5579,1): default region is invalid
> >>>>>GRASS_INFO_ERROR(5579,1): line 15: <depths:     -1074916636>
> >>>>>The relevant file for the region is
> >>>>>DEFAULT_WIND --
> >>>>>proj:       99
> >>>>>zone:       0
> >>>>>north:      213720.89780907
> >>>>>south:      -6149.10219093
> >>>>>east:       -168613.96484194
> >>>>>west:       -404623.96484194
> >>>>>cols:       7867
> >>>>>rows:       7329
> >>>>>e-w resol:  30
> >>>>>n-s resol:  30
> >>>>>top:        1
> >>>>>bottom:     0
> >>>>>cols3:      7867
> >>>>>rows3:      7329
> >>>>>depths:     -1074916636
> >>>>>e-w resol3: 30
> >>>>>n-s resol3: 30
> >>>>>t-b resol:  1
> >>>>>Most of the fields in the file are explained in the REGION section
> >>>>>of the manual, but I can't seem to find anyplace that defines or
> >>>>>explains what the "depths" field is about.  But until I can get
> >>>>>grass to accept the region, I can't do much of anything.
> >>>>>All help is much appreciated...
> >>>>rows,cols, and res=30 all look right. I don't know what is causing the
> >>>>depths to go nuts. Try editing the "WIND" file in your mapset to make
> >>>>depths: 1?
> >>>>maybe this works as a temporary workaround--
> >>>>try viewing the GeoTIFF meta-data with "gdalinfo".
> >>>>If the meta-data is bogus, wipe it clean with:
> >>>>tifftopnm map.tiff | pnmtotiff > map_clean.tiff
> >>>>This will wipe all geo-coding, but you should be able to load into a X,Y
> >>>>location ok and at least view the data. May rectify from there.
> >>>>Hamish
> >>>Thanks, I'll give that a try.
> >>>In response to another reply, this is happening under Grass6.0.0beta2.
> >>>But one of my questions still stands: What does depth represent?  The
> >>>other terms in the
> >>>DEFAULT_WIND file are defined in the g.region documentation, but not
> >>>depth.  If I knew
> >>>what it stands for, perhaps I could guess the right value.
> >>>Thanks for the help!
> >>>david
> > ------- End of Original Message -------
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
