[GRASSLIST:6042] Re: How deep is a region?
    Radim Blazek
    blazek at itc.it
    Mon Mar  7 11:52:15 EST 2005
I see, r.in.gdal was fixed after beta2, should be ok in cvs, just edit
the DEFAULT_WIND and change depths to 1.
Radim
dpadam wrote:
> It was created using r.in.gdal; I haven't been able to do anything further
> because of the "invalid region" errors.
> david
> ---------- Original Message -----------
> From: Radim Blazek <blazek at itc.it>
> To: David Adam <david at quercus.org>
> Cc: grasslist at baylor.edu
> Sent: Mon, 07 Mar 2005 09:39:52 +0100
> Subject: Re: [GRASSLIST:6019] Re: How deep is a region?
>>How was the region file created - what was the last module which
>>modified the region?
>>Radim
>>David Adam wrote:
>>>Hamish wrote:
>>>>>I'm trying to set up a region, starting with a Landsat TIFF
>>>>>image from California.  I have imported the region with r.in.gdal,
>>>>>which produces a large file. I then close grass60 and reopen in the
>>>>>new location, at which point I get the errors
>>>>>GRASS_INFO_ERROR(5579,1): default region is invalid
>>>>>GRASS_INFO_ERROR(5579,1): line 15: <depths:     -1074916636>
>>>>>The relevant file for the region is
>>>>>DEFAULT_WIND --
>>>>>proj:       99
>>>>>zone:       0
>>>>>north:      213720.89780907
>>>>>south:      -6149.10219093
>>>>>east:       -168613.96484194
>>>>>west:       -404623.96484194
>>>>>cols:       7867
>>>>>rows:       7329
>>>>>e-w resol:  30
>>>>>n-s resol:  30
>>>>>top:        1
>>>>>bottom:     0
>>>>>cols3:      7867
>>>>>rows3:      7329
>>>>>depths:     -1074916636
>>>>>e-w resol3: 30
>>>>>n-s resol3: 30
>>>>>t-b resol:  1
>>>>>Most of the fields in the file are explained in the REGION section
>>>>>of the manual, but I can't seem to find anyplace that defines or
>>>>>explains what the "depths" field is about.  But until I can get
>>>>>grass to accept the region, I can't do much of anything.
>>>>>All help is much appreciated...
>>>>rows,cols, and res=30 all look right. I don't know what is causing the
>>>>depths to go nuts. Try editing the "WIND" file in your mapset to make
>>>>depths: 1?
>>>>maybe this works as a temporary workaround--
>>>>try viewing the GeoTIFF meta-data with "gdalinfo".
>>>>If the meta-data is bogus, wipe it clean with:
>>>>tifftopnm map.tiff | pnmtotiff > map_clean.tiff
>>>>This will wipe all geo-coding, but you should be able to load into a X,Y
>>>>location ok and at least view the data. May rectify from there.
>>>>Hamish
>>>Thanks, I'll give that a try.
>>>In response to another reply, this is happening under Grass6.0.0beta2.
>>>But one of my questions still stands: What does depth represent?  The
>>>other terms in the
>>>DEFAULT_WIND file are defined in the g.region documentation, but not
>>>depth.  If I knew
>>>what it stands for, perhaps I could guess the right value.
>>>Thanks for the help!
>>>david
> ------- End of Original Message -------
