[GRASSLIST:6058] Re: XYZ input in Grass6?
Michael Barton
michael.barton at asu.edu
Tue Mar 8 02:16:39 EST 2005
V.in.ascii works for this. I've had the best results using decimal degrees
(I usually use UTM's). Hamish posted a description of the format you need to
use for degrees/minutes/seconds. I don't remember it, but it was within the
past month if you want to check the archives.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> From: Lawrence Moran <lm511 at york.ac.uk>
> Date: Mon, 07 Mar 2005 16:43:07 +0000
> To: GrassList <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:6040] XYZ input in Grass6?
> Having used s.in.ascii in 53 and 54, to import files containing lat long
> depth/height, I'm having difficulty achieving the same in 6.0.0beta (OSX).
> Does anybody know how to import such files in Grass 6?
> Thanks,
> Lawrence
