[GRASSLIST:6143] Re: r.in.gdal and HDF import
Grit Schuster
grit.schuster at geographie.uni-freiburg.de
Sun Mar 13 06:28:34 EST 2005
have a look at http://www.gdal.org/frmt_hdf4.html.
Use gdalinfo to list all multidimensional subdatasets from
the input HDF file.
Then choose the subdateset, which you'd like to import. You
should provide exactly the contents of the line marked
SUBDATASET_n_NAME to GDAL, including the HDF4_SDS: prefix
as
raster file to be imported.
like this:
HDF4_SDS:MODIS_L1B:GSUB1.A2001124.0855.003.200219309451.hdf:2
Hope this will help you,
Grit
On Sun, 13 Mar 2005 11:53:21 +0100
torkild.tveraa at nina.no wrote:
> I'm sorry for being such a pain sending this question
> both to the winGRASS and the GRASS users list. I promise
> to improve in the future : )
> Well, I'm trying to import sea surface temperature data
> obtained in the HDF-format from NOAA using
> grass6.0.cvs/cygwin running on Windows XP, but the
> following message appear:
> ERROR 4: `198501h09ma-gdm.hdf' not recognised as a
> supported dataset name.
> I’ve been through quite a few internet pages this
> weekend, searching for some way to get around this
> problem, but I’ve been unsuccessful so far : ( Is there
> anybody out there who knows how I could get around this
> problem :)
> Thanks in advance,
> Torkild
