[GRASSLIST:6152] Re: v.mkgrid problems again...
Radim Blazek
blazek at itc.it
Mon Mar 14 03:50:00 EST 2005
The horizontal lines are divided by 3:
* For latlon, must draw in shorter sections
* to make sure that each section of the grid
* line is less than half way around the globe
and horizontal lines are written in loop:
x_len = length/3.;
for () {
next_x = x + x_len;
and to get exactly the same value for verticals
for () {
x += x_len;
x += x_len;
x += x_len;
I guess that compiler can optimize the verticals to
x += 3*x_len; and the result will be different.
I have changed that for horizontals in HEAD branch to
x = startx;
for (j = 0; j < 3; j++)
if ( j < 2 )
next_x = x + x_len;
else
next_x = startx + length;
and verticals
for () {
x += length;
which should always give that same value for grid nodes.
Radim
Dylan Beaudette wrote:
> Hi everyone,
> last month I was having some trouble with v.mkgrid producing boundaries,
> centroids, but no areas... after upgrading to GRASS6-beta1 the problem
> was solved. Now with the latest GRASS 6.0.0 source v.mkgrid is not
> producing areas. As a comparison, the GRASS6 package for MacOS X
> produces the correct output.
> Here is a comparison of the output:
> MacOS X Package version of GRASS6:
> GRASS 6.0.0 (pinn):~ > v.mkgrid map=g grid=3,3 ; d.vect g
> Creating vector grid ...
> Writing out vector rows ...
> Writing out vector columns ...
> Creating centroids ...
> Building topology ...
> 57 primitives registered
> Building areas: 100%
> 0 areas built
> 0 isles built
> Attaching islands:
> Attaching centroids: 100%
> Topology was built.
> Number of nodes : 61
> Number of primitives: 57
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 48
> Number of centroids : 9
> Number of areas : 0
> Number of isles : 0
> Number of incorrect boundaries : 48
> Number of centroids outside area : 9
> GRASS 6.0.0 on linux from source code:
> GRASS 6.0.cvs:~ - spearfish57 > v.mkgrid map=g grid=3,3
> 9 areas built
> 1 isles built
> Attaching islands: 100%
> Topology was built.
> Number of nodes : 49
> Number of lines : 0
> Number of areas : 9
> Number of isles : 1
> Any ideas on why this is happening?
> Thanks in advance!
> Dylan
