[GRASSLIST:6168] Re: v.mkgrid problems again...
Dylan Beaudette dylan at iici.no-ip.org
Mon Mar 14 17:43:30 EST 2005
Radim,
Thank you for the reply... but I don't quite understand how this will affect
the operation of v.mkgrid. (sorry i am little dense sometimes!)
Will the newer version of GRASS include v.mkgrid that will produce areas?
Thank you very much for looking at this, it is a really nice module!
Oh, and it looks like in my original email, the Mac OS and Linux output from
v.mkgrid were reversed...!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Monday 14 March 2005 12:50 am, Radim Blazek wrote:
> The horizontal lines are divided by 3:
> * For latlon, must draw in shorter sections
> * to make sure that each section of the grid
> * line is less than half way around the globe
> and horizontal lines are written in loop:
> x_len = length/3.;
> for () {
>      next_x = x + x_len;
> and to get exactly the same value for verticals
> for () {
>      x += x_len;
>      x += x_len;
>      x += x_len;
> I guess that compiler can optimize the verticals to
> x += 3*x_len; and the result will be different.
> I have changed that for horizontals in HEAD branch to
> x = startx;
> for (j = 0; j < 3; j++)
>     if ( j < 2 )
>        next_x = x + x_len;
>     else
>        next_x = startx + length;
> and verticals
> for () {
>      x += length;
> which should always give that same value for grid nodes.
> Radim
> Dylan Beaudette wrote:
> > Hi everyone,
> > last month I was having some trouble with v.mkgrid producing boundaries,
> > centroids, but no areas... after upgrading to GRASS6-beta1 the problem
> > was solved. Now with the latest GRASS 6.0.0 source v.mkgrid is not
> > producing areas. As a comparison, the GRASS6 package for MacOS X
> > produces the correct output.
> > Here is a comparison of the output:
> > MacOS X Package version of GRASS6:
> > GRASS 6.0.0 (pinn):~ > v.mkgrid map=g grid=3,3 ; d.vect g
> > Creating vector grid ...
> > Writing out vector rows ...
> > Writing out vector columns ...
> > Creating centroids ...
> > Building topology ...
> > 57 primitives registered
> > Building areas:  100%
> > 0 areas built
> > 0 isles built
> > Attaching islands:
> > Attaching centroids:  100%
> > Topology was built.
> > Number of nodes     :   61
> > Number of primitives:   57
> > Number of points    :   0
> > Number of lines     :   0
> > Number of boundaries:   48
> > Number of centroids :   9
> > Number of areas     :   0
> > Number of isles     :   0
> > Number of incorrect boundaries   :   48
> > Number of centroids outside area :   9
> > GRASS 6.0.0 on linux from source code:
> > GRASS 6.0.cvs:~ - spearfish57 > v.mkgrid map=g grid=3,3
> > 9 areas built
> > 1 isles built
> > Attaching islands:  100%
> > Topology was built.
> > Number of nodes     :   49
> > Number of lines     :   0
> > Number of areas     :   9
> > Number of isles     :   1
> > Any ideas on why this is happening?
> > Thanks in advance!
> > Dylan
