[GRASSLIST:6184] Re: 3d vectors in NVIZ
Maciek Sieczka werchowyna at epf.pl
Tue Mar 15 17:09:33 EST 2005
dig the grass5 archive and bugtracker
was fixed in Grass 6 release
Maciek
----- Original Message -----
From: "Nick Cahill" <ndcahill at facstaff.wisc.edu>
To: "GRASS mailing list" <GRASSLIST at baylor.edu>
Sent: Tuesday, March 15, 2005 10:02 PM
Subject: [GRASSLIST:6182] 3d vectors in NVIZ
> Trying to use NVIZ to visualize 3d vectors on a DEM surface. All works
> fine - the vector file loads and displays properly until I try to
> change the viewpoint, and then the lighting seems to disappear from the
> surface. The vector file still displays and is lit properly, but the
> surface is almost black. The 3d vector file was created in Microstation
> and imported using v.in.ogr - with no obvious problems. It's a very
> simple geometric structure, and the problem occurs even with the
> simplest 3d vector files. I'm using Lorenzo Moretti's binaries of GRASS
> 6.0 beta 2 cvs, on Mac OSX. Has anybody had any experience with 3d
> vectors in NVIZ?
> Many thanks
> Nick Cahill
