[GRASSLIST:6182] 3d vectors in NVIZ
Nick Cahill
ndcahill at facstaff.wisc.edu
Tue Mar 15 16:02:34 EST 2005
Trying to use NVIZ to visualize 3d vectors on a DEM surface. All works
fine - the vector file loads and displays properly until I try to
change the viewpoint, and then the lighting seems to disappear from the
surface. The vector file still displays and is lit properly, but the
surface is almost black. The 3d vector file was created in Microstation
and imported using v.in.ogr - with no obvious problems. It's a very
simple geometric structure, and the problem occurs even with the
simplest 3d vector files. I'm using Lorenzo Moretti's binaries of GRASS
6.0 beta 2 cvs, on Mac OSX. Has anybody had any experience with 3d
vectors in NVIZ?
Many thanks
Nick Cahill
