[GRASSLIST:6200] RE: V.in.ogr and coor file bytes excess
    geir.systad at nina.no
    Thu Mar 17 06:40:29 EST 2005
When importing shapefiles with areas in the graphical interface, it
hangs (even when the location is projected, and when both the shapefile
and the location is projected, it doesn't matter), and the new vector
file is incomplete. When submitting the same commands as developed in
the graphical interface, it works fine.
v.in.ogr dsn=/cygdrive/c/xxx/periode1a.shp output=p1a min_area=0.0001
snap=-1
Then I have a problem with the graphical interface of v.in.ogr, both for
grass6.0.0Cygwin and grass6.1.cvsCygwin. Has any other seen this?
Geir
System information
OS Name	Microsoft Windows 2000 Professional
Version	5.0.2195 Service Pack 4 Build 2195
OS Manufacturer	Microsoft Corporation
System Name	xxx
System Manufacturer	Dell Computer Corporation
System Model	Precision M40
System Type	X86-based PC
Processor	x86 Family 6 Model 11 Stepping 1 GenuineIntel ~1196 Mhz
BIOS Version	Phoenix ROM BIOS PLUS Version 1.10 A04
Windows Directory	C:\WINNT
System Directory	C:\WINNT\system32
CYGWIN System Information
Platform                Unix
Operating System        CYGWIN_NT-5.0
OS Version              1.5.13(0.122/4/2)
Processor Type (arch)   i686
Full OS ID              CYGWIN_NT-5.0-1.5.13(0.122/4/2)-i686
Tcl Version/Patchlevel  8.4.7
Name of Executable      /usr/local/bin/wish
Name of current Script  /usr/local/grass6.1.cvs/etc/dm/tksys.tcl
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Systad, Geir
Sent: Wednesday, March 16, 2005 2:14 PM
To: grasslist at baylor.edu; wingrass at grass.itc.it
Subject: [GRASSLIST:6193] V.in.ogr and coor file bytes excess
Sorry for the last header, it was not an answere to the GRASSLIST:6191
message -
I use the graphical interface of Grass6.0.0 Cygwin stable (feb
something).
I have tried to import shapefiles into grass, and get messages like
this:
snap=-1
PROJ_INFO file not found for location N50kart
PROJ_UNITS file not found for location N50kart
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: periode1a
Building topology ...
Registering lines:
238 primitives registered
Building areas:
238 areas built
238 isles built
Attaching islands:
Attaching centroids:
When I try to present it on maps, only the boundaries of the areas show
up -
GRASS 6.0.0 (N50kart):~ > WARNING: coor files of vector 'p1a at PERMANENT'
is larger than it should be
         (33479 bytes excess).
WARNING: Cannot display areas, topology not available
WARNING: Cannot display topology, not available
When I use v.external, the map writes out afterwards without problems.
The number of primitives is different.
v.external dsn=/cygdrive/c/xxx/periode1a.shp output=p1d layer=periode1a
Building topology ...eature:     100   200 238
Topology was built.
Number of nodes     :   476
Number of primitives:   476
Number of points    :   0
Number of lines     :   0
Number of boundaries:   238
Number of centroids :   238
Number of areas     :   238
Number of isles     :   238
What is the problem with the coor file made by v.in.ogr? Can anyone
help?
Sincerely,
Geir
