[GRASSLIST:6202] Re: Problems with r.out.bin
Patricio Toledo Peña
patoledo at ing.uchile.cl
Thu Mar 17 14:22:40 EST 2005
yes, i am aware of the weird syntax to access float and integer data on GMT.
But the problem is in r.out.bin, the raw netCDF file is ok in terms of the
SRTM but it is not the same thing with the SPOT data as viewed with ncdump.
ok?
I will check the FCELL, DCELL stuff
Thanks a lot
El 16 Marzo 2005 20:06, Dylan Beaudette escribió
> This may or may not be related.... but:
> I have found that GRASS DCELL maps must first be converted to FCELL maps,
> before exporting to a GMT-ready format.
> Also when accessing grid files exported from GRASS with a GMT program be
> sure to use the following syntax:
> float_grid_file.grd=1 (read as float grid)
> integer_grid_file.grd=2 (read as int grid)
> ..it looks like your spot data is integer, so reading the file with an
> appended "=1" will cause GMT to read the file as if it were a float grid.
> I have documented some of my GRASS-GMT findings here:
> http://169.237.35.250/~dylan/grass_user_group/
> Cheers,
Departamento de Geofísica
Universidad de Chile
