[GRASSLIST:6223] compilation error
    sisma66 at tiscali.it
    Mon Mar 21 18:19:22 EST 2005
Dear GRASS User
I'm tring to compile a stable grass6 version on my laptop using the below
configure command:
./configure --with-opengl-includes=/usr/X11R6/include/ --without-odbc
--without-fftw --with-postgres-includes=/usr/include/pgsql/
--with-gdal=/usr/local/bin/gdal-config --with-freetype
--with-freetype-includes=/usr/include/freetype2
and I haven't any error (this below is the output)
GRASS is now configured for:  i686-pc-linux-gnu
 Source directory:            /home/pierluigi/grass_source/grass-6.0.0
 Build directory:             /home/pierluigi/grass_source/grass-6.0.0
 Installation directory:      /usr/local/grass-6.0.0
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -O2
 C++ compiler:
 FORTRAN compiler:
 Building shared libraries:   yes
  NVIZ:                       yes
  X11 support:                yes
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  Tcl/Tk support:             yes
  PostgreSQL support:         yes
  MySQL support:              no
  OpenGL(R) support:          yes
  ODBC support:               no
  FFTW support:               no
  BLAS support:               no
  LAPACK support:             no
  Motif support:              no
  FreeType support:           yes
  GLw support:                no
  NLS support:                no
  Readline support:           no
  C++ support:                no
  openDWG support:            no
  GDAL support:               yes
  OGR support:                yes
then I run "make" but I have error in any single grass modules.
Started compilation: ven mar 18 13:47:58 CET 2005
Errors in:
/home/pierluigi/grass_source/grass-6.0.0/db/drivers/dbf
/home/pierluigi/grass_source/grass-6.0.0/db/drivers/postgres
/home/pierluigi/grass_source/grass-6.0.0/db/drivers/ogr
/home/pierluigi/grass_source/grass-6.0.0/db/base
/home/pierluigi/grass_source/grass-6.0.0/db/db.login
/home/pierluigi/grass_source/grass-6.0.0/display/drivers/XDRIVER/XDRIVER24
/home/pierluigi/grass_source/grass-6.0.0/display/drivers/PNG
/home/pierluigi/grass_source/grass-6.0.0/display/d.ask
/home/pierluigi/grass_source/grass-6.0.0/display/d.barscale/home/pierluigi/grass_source/grass-6.0.0/vector/v.reclass
/home/pierluigi/grass_source/grass-6.0.0/vector/v.sample
/home/pierluigi/grass_source/grass-6.0.0/vector/v.segment
/home/pierluigi/grass_source/grass-6.0.0/vector/v.select
/home/pierluigi/grass_source/grass-6.0.0/vector/v.surf.idw
/home/pierluigi/grass_source/grass-6.0.0/vector/v.surf.rst
/home/pierluigi/grass_source/grass-6.0.0/vector/v.transform
/home/pierluigi/grass_source/grass-6.0.0/vector/v.to.db
/home/pierluigi/grass_source/grass-6.0.0/vector/v.to.points
/home/pierluigi/grass_source/grass-6.0.0/vector/v.to.rast
/home/pierluigi/grass_source/grass-6.0.0/vector/v.type
/home/pierluigi/grass_source/grass-6.0.0/vector/v.univar
/home/pierluigi/grass_source/grass-6.0.0/vector/v.voronoi
/home/pierluigi/grass_source/grass-6.0.0/vector/v.what.rast
/home/pierluigi/grass_source/grass-6.0.0/vector/v.vol.rst
/home/pierluigi/grass_source/grass-6.0.0/vector/v.out.ogr
/home/pierluigi/grass_source/grass-6.0.0/vector/v.in.ogr
/home/pierluigi/grass_source/grass-6.0.0/vector/v.external
/home/pierluigi/grass_source/grass-6.0.0/visualization/nviz
Finished compilation: ven mar 18 13:51:09 CET 2005
The errors are in each modules and if I run make install (under root) I have
this....
[root at localhost grass-6.0.0]# make install
echo /home/pierluigi/grass_source/grass-6.0.0/bin.i686-pc-linux-gnu/grass60
ERROR: GRASS has not been compiled. Try "make" first.
  Installation aborted, exiting Make.
Can you help me??
Maybe the problem is inside my machine because the error is in each modules
but I don't know what is...
thaks in Advance
Pierluigi
__________________________________________________________________
Tiscali Adsl 3 Mega Flat con 3 MESI GRATIS!
Con Tiscali Adsl 3 Mega Flat navighi con la Supervelocita'
a soli 29.95 euro al mese, senza limiti di tempo. E se attivi
entro il 31 Marzo, 3 MESI sono GRATIS!
Scopri come su http://abbonati.tiscali.it/adsl/sa/2flat_tc/
