[GRASSLIST:6243] Re: r.in.bin all nan import GMT grd file.
    Gordon Keith
    gordon.keith at csiro.au
    Thu Mar 24 00:03:25 EST 2005
After more effort (recompiling gdal --with-netcdf) I can now get a raster of
all nans from a normal GMT grid using r.in.gdal as well as from a type 1 grid
using r.in.bin.
In both cases the program runs successfully and correctly gets the region
information from the grid file, but no data.
r.in.gdal thinks the projection is x,y, but it is in fact lat,lon. But i get
the same result using the -o and location= options.
Thoughts?
On Thu, 24 Mar 2005 12:26, Gordon Keith wrote:
> I'm trying to import some GMT grd files into grass. I think I have done
> this successfully a long time (and several versions) ago, but now I can't
> get it to work.
> r.in.bin -hf seems to work, but all the data is nans. r.info reports:
>  |   Range of data:    min =  nan max = nan
> I know the grd file is not all nans because I can generate plots from it in
> GMT.
> Any suggestions?
> This is grass 6.0 on intel/linux, the same machine generated the grd files.
> Regards
> Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
"But what... is it good for?"
- Engineer at Advanced Computing Systems Division of IBM, 1968,
commenting on the role of the microchip.
