[GRASSLIST:6267] Re: r.in.gdal LatLong projection: G_set_window():
Illegal latitude for North
Zaboj Hrazsky, DAPHNE CZ - Institut of applied ecology
zaboj.hrazsky at daphne.cz
Mon Mar 28 03:32:20 EST 2005
GRASS6.0 compiled with PROJ4 4.4.9 version runs on my debian sarge...
but with patched PJ_krovak.c.
Detailed description in czech ...
http://mpa.itc.it/radim/jtsk/index.html
and here is the patch personaly...
http://mpa.itc.it/radim/jtsk/PJ_krovak.c.patch
(shortly: run "patch PJ_krovak.c PJ_krovak.c.patch" for the file
PJ_krovak.c in PROJ4 src tree before compilation of PROJ4)
And everything works...
I overide the bug with Radim Blazek help:
1) to import into new location (see g.manual r.in.gdal)
2) to change projection for new location running g.setproj from xy to
LatLong with wgs84 datum
3) to modify "GRASSDATA_DIR"/"LOCATION"/"MAPSET"/cellhd/"MAPNAME" file
changing first line:
from "proj: 0" to "proj: 3"
#signals type of location (xy versus LatLong)
After these r.proj was running without problems and reprojected maps
match the others from krovak (s-jtsk) location.
... but thanks for your experiences it seems PROJ4 library need the 5
version with improved PJ_krovak.c :-).
Zaboj
Kingsley Burlinson wrote:
> Zaboj
> It is possible there is a problem in the PROJ4 libraries for the
> krovak projection and perhaps this is causing your problems. I am just
> compiling grass now and I had major errors with PROJ4 version 4.4.9
> and had to remove the krovak projection to get it to compile at all.
> Perhaps you can try another projection and see if it works in that to
> check this potential problem.
> I have notified the PROJ4 list of this but have had no reply yet.
> Kingsley Burlinson Darwin
> Zaboj Hrazsky wrote:
>> Troubles with r.in.gdal import:
>> I have found following constraint when I tried import WORLDCLIM dataset:
r.in.gdal LatLong projection: G_set_window(): Illegal latitude for North
