[GRASSLIST:6286] Re:Re: GPS points off by about 120m to the west
Michele
michele.rocc at libero.it
Wed Mar 30 03:11:51 EST 2005
> > the GPS was set for the same projection parameters...
I think that what Mr. Hamish said is true, and suggest to convert points from wgs84
to your datum using v.proj.
Michele.
> The GPS is exporting waypoints in WGS84;
> the error you are seeing is surely due to a datum shift;
> v.in.garmin should take care of all that for you.
> i.e. regardless of what you have the GPS datum set to display on the
> screen, it will output WGS84. At least that what my Garmins do.
> were you importing with v.in.garmin or v.in.ascii?
> note v.in.garmin in 6.0 is broken, get the latest version of the script
> from CVS.
> Hamish
____________________________________________________________
Navighi a 2 MEGA e i primi 3 mesi sono GRATIS.
Scegli Libero Adsl Flat senza limiti su http://www.libero.it
