[GRASSLIST:6704] Re: Creating points on line with calculated
value.
Radim Blazek
blazek at itc.it
Tue May 3 05:44:53 EDT 2005
Iñigo Marin wrote:
> I'm also interested in that module
> But I don´t know how to compile modules!!
> Can anyone tell me what do I need to get it using cygwin.
> Do I need any cygwin's libraries or programs apart from those needed to
> run grass6.0 ?
> Do I need the grass source code ?
> I get this message:
> bash-2.05b$ make
> Makefile:11: ../../include/Make/Dir.make: No such file or directory
> make: *** No rule to make target `../../include/Make/Dir.make'. Stop.
> bash-2.05b$
You have to put it to grass6 source subdir, e.g.
grass6/my/v.lrs so that Makefile can find ../../include/Make
Radim
> Thanks
> Respeta el medio ambiente. Antes de imprimir este e-mail, piensa si
> realmente es necesario.
> Respect the environment. Before printing this e-mail, think if it's
> really necessary.
> -----Mensaje original-----
> De: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] En
> nombre de Hamish
> Enviado el: martes, 03 de mayo de 2005 10:26
> Para: maris.nartiss at gmail.com
> CC: GRASSLIST at baylor.edu
> Asunto: [GRASSLIST:6702] Re: Creating points on line with calculated
> value.
>>I have 2 points with values and a line connecting them (i.e. 2 cities
>>and road between them) as two vector files (from 2 shapefiles). I need
>>to create new points on this line in some distance (step) with values
>>smoothly changing form first point value to second point value. New
>>point values have to depend on distance on line from start point.
>>Example:
>>Input: 5 - - - - 10
>>Output:5 6 7 8 9 10
>>As line can be not straight, just creating rast with interpolated
>>values and then uploading rast values to new pionts on line (ie. from
>>v.segment) doesnt solve my problem.
>>Any help welcomed :)
>>I already looked on v.net.* commands, but could not understand a bit
>>from manual. I can understand how to run them, but not what they do :)
> checkout Radim's LRS.
> http://mpa.itc.it/radim/lrs/index.html
> Hamish
