[GRASSLIST:6784] GRASS 6 build/run problems on Linux
Thomas Adams
Thomas.Adams at noaa.gov
Fri May 13 19:58:01 EDT 2005
I have pretty much successfully built GRASS 6 to run on Redhat Linux 7.3
with a couple of exceptions. First off, I configured with:
gdal 1.2.3
fftw 3.0.1
PostgreSQL 7.4.7
proj 4.4.9
However, problem (1) I had to configure without fftw because the
includes could not be found:
checking whether to use FFTW... yes
checking for location of FFTW includes...
/awips/rep/lx/local_apps/fftw/include
checking for fftw.h... no
checking for dfftw.h... no
configure: error: *** Unable to locate FFTW includes.
However, in the fftw install directory were:
fftw3.f fftw3.h
Should I be using an older version of fftw? I ran the test for the
install and everything verified. OK, I *can* live without fftw.
The big problem occurs when I try to run GRASS 6, the display manager
fails to start and I get:
GRASS-GRID > Error in startup script: ps.map: error while loading shared
libraries: libgdal.so.1: cannot open shared object file: No such file or
directory while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 32)
invoked from within
"main $argc $argv"
(file
"/awips/rep/lx/local_apps/grass6-build/grass-6.0.0/etc/dm/d.m.tcl" line 894)
I copied the gdal libs to /usr/local/lib and made sure it was in my
path, but to no avail. I had to install gdal, fftw, proj, PostgreSQL,
and GRASS 6 in the directory /awips/rep/lx/local_apps/ due to local
admin restrictions.
GRASS 6 runs from the command line, FWIW.
Any ideas?
BTW, GRASS 5.4 installed and runs without problems.
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
