[GRASSLIST:6785] Re: GRASS 6 build/run problems on Linux
Glynn Clements
glynn at gclements.plus.com
Fri May 13 23:17:34 EDT 2005
Thomas Adams wrote:
> I have pretty much successfully built GRASS 6 to run on Redhat Linux 7.3
> with a couple of exceptions. First off, I configured with:
> gdal 1.2.3
> fftw 3.0.1
GRASS needs FFTW 2.x; 3.x isn't compatible.
> PostgreSQL 7.4.7
> proj 4.4.9
> However, problem (1) I had to configure without fftw because the
> includes could not be found:
> checking whether to use FFTW... yes
> checking for location of FFTW includes...
> /awips/rep/lx/local_apps/fftw/include
> checking for fftw.h... no
> checking for dfftw.h... no
> configure: error: *** Unable to locate FFTW includes.
> However, in the fftw install directory were:
> fftw3.f fftw3.h
> Should I be using an older version of fftw?
Yes.
> I ran the test for the install and everything verified. OK, I *can*
> live without fftw.
FFTW is required for i.fft, i.zc and r.surf.fractal. If you don't need
those modules, you don't need FFTW.
> The big problem occurs when I try to run GRASS 6, the display manager
> fails to start and I get:
> GRASS-GRID > Error in startup script: ps.map: error while loading shared
> libraries: libgdal.so.1: cannot open shared object file: No such file or
> directory while executing
> "exec ps.map -p"
> (procedure "DmPrint::init" line 14)
> invoked from within
> "DmPrint::init"
> (procedure "main" line 32)
> invoked from within
> "main $argc $argv"
> (file
> "/awips/rep/lx/local_apps/grass6-build/grass-6.0.0/etc/dm/d.m.tcl" line 894)
> I copied the gdal libs to /usr/local/lib and made sure it was in my
> path, but to no avail. I had to install gdal, fftw, proj, PostgreSQL,
> and GRASS 6 in the directory /awips/rep/lx/local_apps/ due to local
> admin restrictions.
> GRASS 6 runs from the command line, FWIW.
> Any ideas?
Check that /usr/local/lib is listed in /etc/ld.so.conf, then run
"ldconfig" as root.
