[GRASSLIST:6795] Re: GRASS 6 build/run problems on Linux
Thomas Adams Thomas.Adams at noaa.gov
Mon May 16 13:01:45 EDT 2005
Glynn,
That did the trick. However, I also needed to copy the gdal & proj (and
others) libs to the GRASS 6 lib directory due to our local admin setup.
But it works; thanks for your help.
Regards,
Tom
Glynn Clements wrote:
>Thomas Adams wrote:
>>I have pretty much successfully built GRASS 6 to run on Redhat Linux 7.3
>>with a couple of exceptions. First off, I configured with:
>>gdal 1.2.3
>>fftw 3.0.1
>GRASS needs FFTW 2.x; 3.x isn't compatible.
>>PostgreSQL 7.4.7
>>proj 4.4.9
>>However, problem (1) I had to configure without fftw because the
>>includes could not be found:
>>checking whether to use FFTW... yes
>>checking for location of FFTW includes...
>>/awips/rep/lx/local_apps/fftw/include
>>checking for fftw.h... no
>>checking for dfftw.h... no
>>configure: error: *** Unable to locate FFTW includes.
>>However, in the fftw install directory were:
>>fftw3.f  fftw3.h
>>Should I be using an older version of fftw?
>Yes.
>>I ran the test for the install and everything verified. OK, I *can*
>>live without fftw.
>FFTW is required for i.fft, i.zc and r.surf.fractal. If you don't need
>those modules, you don't need FFTW.
>>The big problem occurs when I try to run GRASS 6, the display manager
>>fails to start and I get:
>>GRASS-GRID > Error in startup script: ps.map: error while loading shared
>>libraries: libgdal.so.1: cannot open shared object file: No such file or
>>directory while executing
>>"exec ps.map -p"
>>    (procedure "DmPrint::init" line 14)
>>    invoked from within
>>"DmPrint::init"
>>    (procedure "main" line 32)
>>    invoked from within
>>"main $argc $argv"
>>    (file
>>"/awips/rep/lx/local_apps/grass6-build/grass-6.0.0/etc/dm/d.m.tcl" line 894)
>>I copied the gdal libs to /usr/local/lib and made sure it was in my
>>path, but to no avail. I had to install gdal, fftw, proj, PostgreSQL,
>>and GRASS 6 in the directory /awips/rep/lx/local_apps/ due to local
>>admin restrictions.
>>GRASS 6 runs from the command line, FWIW.
>>Any ideas?
>Check that /usr/local/lib is listed in /etc/ld.so.conf, then run
>"ldconfig" as root.
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050516/5edc5682/attachment.html
